1st Gen Intrepid 1993 through 1997 Intrepids
egr problems?
Old Jun 12, 2011 | 10:57 PM
redmuck's Avatar
redmuck
Default egr problems?
i hav a 93 3.3 intrepid and its running crappy,so i checked every sensor and if they are bad i put new ones on. it still has no power and pick up,its shifting every gear at 3 grand. now the vacuum test for the egr passed, which its supposed to be good,so with it running, i unplugged the eet egr electrical connector and there was no change in idle or anything. should it run worse if it was good? oh yea new catalytic converter too. maybe the solenoids in the trans are making it shift bad? i took it to a trans shop and they said everything was fine except the catalytic converter was clogged,oh the car was running 95% perfect before i took it to them, it was just kinda jerking,like the trans slipping between 40mph and 65mph. they even told me the trans fluild didnt need to be changed and its been since 06 when it was done.seems like the fuel system is good,fuel injectors are clicking, new fuel filter, new vapor cannister,i can feel the purge solenoid pumping. im not sure what to do next, im about ready to trade it in for something else if i can.
Old Jun 17, 2011 | 11:39 PM
redmuck's Avatar
redmuck
Default no answers or opinions?
no one has any answers or opinions?
