97 intrepid no start
It started the other when I went out to start the car and the battery was dead. So I poked around and seen a light was on so figured I just drained it as I only use it for work and it usually sits for 3 to 4 days at a time. I gave it a jump and took it for a spin to try and charge the battery back up. I got about a half mile and the battery light came on, then it shut off. I went and got a new battery, but now it wont start. It cranks over fine but wont fire up. Any ideas?
Here is an update... If I use starter fluid it will start for a moment but then stalls out. I find it hard to believe my fuel pump could be bad at the exact time as my battery issues. I've checked the fuses and swapped out the relays. Do these have a fuel shutoff switch somewhere that I'm missing?
