1st Gen Intrepid 1993 through 1997 Intrepids
Weird problem with cooling fans. Please help.
Old Dec 9, 2005 | 01:13 PM
DAIadvisor's Avatar
DAIadvisor
Default Weird problem with cooling fans. Please help.
I have a 1994 Intrepid ES 3.5 - In the last few weeks, the fans will start as soon as you turn the car on - one at first, and then the second fan will kick on. Sometimes they will shut down, and kick on 2 seconds later, and will be doing that the whole time I'm driving. On a freezing day (like today) fans are on almost all the time, shutting down for literally couple seconds and starting again.
I changed the temp sensor (top of the engine near the radiator hose), and it has full antifreeze.
I would appreciate any suggestions on this issue. Thank you.
Old Dec 14, 2005 | 12:35 PM
Ramrat's Avatar
Ramrat
Default RE: Weird problem with cooling fans. Please help.
sounds alot like anouther post in here on a 95 3.3, try swaping the fan relay with the horn relay, if it fixes it there about 10 bucks a advanced auto, all the relays in that box are the same so it won't damage anything to try, good luck and let us know how you make out as it seems to be happaning with the neon to
Old Dec 28, 2005 | 08:56 PM
engs0062's Avatar
engs0062
I am having the same problem with mine, a 96 with 3.5 liter and 150,xxx on it. Just today, in Minnesota weather, started the car and obviously it was cold. Was just running a quick errand and the whole way there the fans were on before the temp gauge even moved. Just went out right now to switch the relays, but wanted the fans to kick on before I shut it off and switched them, and they never came on, beats me!
So if the relay swap doesn't work, must be a sensor? Any ideas?
Does anyone have troubles with the cooling system in these? Evertime I get low on coolant (in the resevoir) she sucks a lot of air and I have to pull over, add coolant and bleed the thermostat. The last time it happened, had about 2 minutes of straight air with a little coolant spitting out the nipple on the thermostat, and yes thermostat is new from last time this happened a few months ago.
Anyone else have these problems and what do you do? Thanks,
Lee
