1st Gen Intrepid 1993 through 1997 Intrepids
Removing cats on a ’95 In
Old Nov 3, 2003 | 11:18 PM
Igor's Avatar
Igor
Default Removing cats on a ’95 In
Hey guys. </P>
I was looking at the exhaust on my '95 Intrepid 3.3L, and it looks like it has 3 cats. Not sure where the O2 sensors are located, but can I remove these cats with no computer problems? I have no emmisions testing here and removing "faulty" cats is legal. Done on all my other cars. Thanks guys. </P>
Old Nov 4, 2003 | 02:19 AM
71RoadRunner's Avatar
71RoadRunner
Yes. You can only do away with the O2 sensors that are in or after the cats. All you need to be bothered with is the check engine light coming on and staying on. To eliminate the check engine light Jegs has O2 sensor simulators that plug into the wiring at the O2 sensor instead of the O2 sensor itself. Problem solved.<edited><editID>71ROADRUNNER</editID><editDate>37928.9740509259</editDate></edited>
