1st Gen Intrepid 1993 through 1997 Intrepids
Connecting OBD to DRB III
Old Mar 4, 2006 | 07:12 PM
bcallpres's Avatar
bcallpres
Default Connecting OBD to DRB III
The AutoXray EZ-Read 2000 scan tool can be used to connect to the DRB III port under the steering column. You must make up 3 jumpers to go from the LH connector under the dash to the Chrysler AutoXray connector cable. Hope this helps others. Unfortunately, I still couldn't get a breakdown of whether code 66 was a problem communicating with the PCM or the BCM. I guess it is just the OBD II that use the four digit codes listed in the Haynes manual.
AutoXray term. LH connector
1 6
3 5
4 1
See diagram. Also available at http://www.autoxray.com/9495lh.htm
[IMG]local://upfiles/28883/226860DECE8548BE8F17F4AC161CD91E.jpg[/IMG]
