1st Gen Intrepid 1993 through 1997 Intrepids
code 54 94 intrepid
Old Mar 10, 2006 | 06:14 PM
jamienfld's Avatar
jamienfld
Default code 54 94 intrepid
I have 94 intrepid 3.3 getting code 54 and car won't start. I changed the cam sensor and code 54 still comes up but still wont start any ideas? It was running and use to shut off after few mins. Then start up again if you waited about 10 mins but now won't start at all
Old Mar 10, 2006 | 08:29 PM
ViperGTS's Avatar
ViperGTS
Default RE: code 54 94 intrepid
http://www.troublecodes.net/chrysler...30333538.shtml
54: Fault In Distributor High Data Rate Pickup Circuit{1}
54: And/Or No Sync Pickup Signal{2}
Hope that helps
Old Mar 10, 2006 | 09:13 PM
jamienfld's Avatar
jamienfld
The car don't have a Distributor. I tryed new cam sensor , new crank sensor, coil pack, and pcm still wont start. I get power to coil through plug but no single going through plug to fire coil. So i don't get any spark I hooked up trouble light to the plug on each of the 3 wires says in book light should blink when you crank engine but it won't. I only get the power going form the forth wire.
Old Sep 4, 2006 | 09:57 PM
ryanp77's Avatar
ryanp77
Having same problem, only I additionally have error code 13. Any updates or thoughts on what this could be?
Old Oct 29, 2006 | 05:48 PM
kurts2's Avatar
kurts2
I once had the same problem with my Jeep, it turned out to be a dirty connector from the crank possition sensor. With the code you are getting, it sounds like you are on the right track. Have you shot the wire harness for resistance? If it is high it will mess up the value for the sensor and you will not get a fire pulse signal at the coil pack. There is also the posibility that one of the sernsors you put in was defective, I would ohm ck them and at least compare the values to the old ones you removed. Who knows, maybe it will be obvious like an open at onr of the sensors or in the harness. Good luck.
