1st Gen Intrepid 1993 through 1997 Intrepids
96' Intrepid
Old May 29, 2006 | 12:44 PM
roger_decker69's Avatar
roger_decker69
Default 96' Intrepid
[font="Times New Roman"][/font]I have a 96' Intrepid,3.5 liter auto. with a/c. I am having a few problems with it and hope someone can PLEASE help me!!! 1st.) A/C doesn't work only once in a while mysteriously when it wants to;I get a code saying I have a problem with the a/c clutch relay(CODE 33). I replaced the relay twice - still did nothing, if I cross /jump the relay across two of the terminals one for the coil inside it and with one of the others (doesn't work with all remaining terminals just the two) it will work fine until the lines freeze over do to being hooked directly. I do not know if the problem is in the a/c heater control head((instrument panel) seeing it has a computer in it ;and I checked the codes on it and it seems to work all right but it still blows hot air.) or if it is something else(but what could it be???). Both the high and low speed fans are turning as soon as the car is started, I am told that one of the fan is suppose to be going on and off with the a/c (which one I do not know;even if it needs to be wired like that (I was told that the guy I bought the car from wired the two together). 2nd.) I would appreciate it if anybody could tell me what I have to do to Solve these codes(?) : CODE 52(o2 sensor - side 1/bank 1 - if some one could tell me which one this is ? , CODE32 (open/shorted Egr solenoid-possible air/fuel ratio imbalanced not detected, and CODE66 Pcm not receiving ccd Bus signals.
Thank You, For Any Help You Can Give Me,Since The Accident I was in I can't crawl all over and under the car easily;I have to know right where it is, If I can get to it ,Or if my son(14) can do it as I tell him how-but I need anyones help so I can do this either way please!
