1st Gen Intrepid 1993 through 1997 Intrepids
'95 Intrepid stumbling/ignition cutting in/out, need help ASAP!!!
Old Jul 6, 2004 | 12:52 PM
Igor's Avatar
Igor
Default '95 Intrepid stumbling/ignition cutting in/out, need help ASAP!!!
My car one day just died on the way to work, then restarted and all was well. Three days later, it died in the driveway and would not start. I was getting code 54. So I changed the crank sensor, did nothing. Changed the cam sensor and took the coil pack off to check connection, put it back on, car fired right up (so I figured it was the cam sensor) and ran great. That was yesterday.
Today, on my way to work (highway about 1 hour), after it warmed up nice, it started to missfire and jerk, and then the check engine light would start flashing. Now, I am getting code 43 and code 54 (mind you, I never reset the codes when I was done yesterday, so 54 might be old). I made it home, but the car hardly runs. So gonna let it cool down and try.
Also, I have a set of wires and plugs, gonna change them too and see if it makes a difference. I need to solve this problem ASAP so I can get to/from work. Any help would be great. Thanks a lot!
