1st Gen Intrepid 1993 through 1997 Intrepids
intrepid headlight
Old Dec 4, 2006 | 03:56 PM
ramsportguy's Avatar
ramsportguy
Default intrepid headlight
i dont see why not but remember to cut it right near the plug and strip the wires and solder the wires and before you do that to put some heat shrink on before you rewire it so once yer done with the new plug to heat shrink the new connections and take a lighter and heat the heat shrink n it`ll make a weatherproof tight bond and you`ll be good to go.Taking it from another car should be good but before you do that try a parts store see if they may have em if not go for a j/y intrepid..
thanks
pat
Old Dec 4, 2006 | 06:18 PM
Intrepid Scarface's Avatar
Intrepid Scarface
Default RE: intrepid headlight
And what are you talking about?
Did you post that as a reply to another kid asking about soldering wires?
https://dodgeforum.com/m_633297/tm.htm
Old Dec 5, 2006 | 06:57 AM
ramsportguy
Yeah i guess i hit fast reply to his question and not realized it.. DOH [:'(]
thanks
pat
