1st Gen Intrepid 1993 through 1997 Intrepids
ABS light
Old Dec 18, 2006 | 04:42 PM
fordtractorman's Avatar
fordtractorman
Default ABS light
Hi all. I've noticed lately that occasionally, the "Brake" light on the dash will light up for a few seconds then go off. What does this mean? The old car stops good, just not sure why the light is coming on now. Thanks.
Old Dec 21, 2006 | 07:15 AM
ramsportguy's Avatar
ramsportguy
Default RE: ABS light
Does it do it on hard braking?My 94 eagle vision was doing that, i added some brake fluid and it stopped.Try adding some fluid it may be the cure.I believe theres a sensor where at just a hairline once it goes down it`ll trip it off and once you release the brake the fluid level come back up.So try the adding of the fluid..
thanks
pat
