Neon EGR System
Old Mar 29, 2007 | 08:15 PM
protivakid's Avatar
protivakid
Default Neon EGR System
Hey,
My question is, do you guys think the EGR system in the Neon is necessary and or causes a loss in performance? I was reading all about vehicle emissions and know that the EGR means Exhaust Gas Recirculation which seems to me like it would decrease the Neon's performance. I have heard of someone who disconnected his in his Neon and was wondering is that’s a wise thing to do or if it would help increase performance at all. I know obviously it may mess up your vehicle NOx when you go to get your emissions tested for state inspection. Just wondering your thoughts not really knowing myself much about a car's emissions system.
I have also posted a pic of a valve on top of the DOHC engine, probably on the SOHC one as well. I know the other end leads into your air intake, what is this valve, just a breather valve or is it something that would be better off w/ a breather filter on it rather than connected to the air intake? Thanks in advance.
Old Mar 29, 2007 | 08:23 PM
das2123's Avatar
das2123
Default RE: Neon EGR System
Blocking or removing the EGR system will not affect performance at all. It won't hurt you nor give you any gains.
You can attach a breather filter to the valve, but why? It's already getting filtered air attached to the tube.
