transmission 3rd gear
Old Mar 31, 2007 | 12:48 AM
97dohc's Avatar
97dohc
Default transmission 3rd gear
I almost have her done. Thank you for your help. You've gotten me through everything else and now I have another problem:
When the car is cold it has an issue shifting into 3 rd gear. I have to take it up to around 75mph before it shifts. After that it increasingly gets easier to shift into 3rd gear. Once it's warm no problem at all. I do not know what to try to fix it. It was previously sitting for 2 years. Then I did the head gasket and timing and she runs great except for the shifting problem. It had no issue what so ever when parked with the blown head gasket 2 years ago. Any suggestions on how to fix this would be great thanks
Thefluid is full and I added a bottle of Lucus too. What do you think? Thanks in advance.
Old Mar 31, 2007 | 07:16 AM
racerx55's Avatar
racerx55
Default RE: transmission (overdrive)
ive never seen an overdirve autoneon trans.. did i miss something?
Old Mar 31, 2007 | 01:25 PM
das2123's Avatar
das2123
Neons don't have an overdrive...that is the torque lockup converter kicking on.
You should not add anything to the tranny fluid. Mopar ATF+4 is ALL you need.
Old Mar 31, 2007 | 03:09 PM
neisg1's Avatar
neisg1
Has the trans. fluid and filter been changed? A clogged filter can sometimes restrict flow when cold and act normal when warm. Recommended fluid and filter change is every 30,000 miles but I know a lot of people never do.
