Neon Coupe Window Parts, Need Help!
Old Apr 1, 2007 | 03:54 PM
unclemike's Avatar
unclemike
Default Neon Coupe Window Parts, Need Help!
We replaced the driver's door window regulator in the daughter's 1996 Neon Highline Coupe. We had no problems for the first year then the window started to sag at the back and you had to help it up. Turns out that the bracket on the rear part of the glass has broken. Apparently I didn't have everything aligned correctly and the bracket would flex as the window was rolled up and down.
The problem is the bracket isn't sold seperately according to the Dodge partsguy. I need that bracket if anybody out there has a wrecked coupe with a broken driver's side window. The brackets might be left and right but I'm not really sure. Also if anybody knows where I could buy one new? Thanks for any help.
Old Apr 2, 2007 | 02:58 PM
crow01's Avatar
crow01
Default RE: Neon Coupe Window Parts, Need Help!
You could try a junkyard, but 2 doors are hard to come by. I had this problem in a 1998 r/t, and a 1997 coupe. I believe the part is the same for power and crank windows. I couldn't find a decent one in a junkyard so I had to go to the dealer. Part # 04783723 should be about $50. This is the bracket and the rail in one piece. Unfortunately, this bracket is made out of "white metal", and is sorta cheap. Hope this helps.
