broken
Old Apr 4, 2007 | 02:55 PM
ohioguru's Avatar
ohioguru
Default broken
well today i wax working on my satellite and i ended up trippin in my grage and landed on my passenger side mirrior on the neon.....it broke in like 3 places.....so how do i put a new one on ?
Old Apr 4, 2007 | 03:52 PM
spudsterier's Avatar
spudsterier
Default RE: broken
is it a manual mirror or power????
if its manual windows then:
if you dont wanna remove the door panel:
remove the little plastic cover on the inside of the door panel opposite side if the mirror by pulling it out and then down......
then once the cover is off you will see 3-10mm bolts....unbolt them and pull the mirror off
if its a power mirror then you have to remove the door panel so that you can get to the wire clip....
