2.4L engine swap
Old Apr 5, 2007 | 04:10 AM
streetracer603's Avatar
streetracer603
Default 2.4L engine swap
have any of yall done the 2.0 to 2.4 swap?if u have wat ecu(computer)did u use
Old Apr 5, 2007 | 11:44 AM
das2123's Avatar
das2123
Default RE: 2.4L engine swap
You use a DOHC PCM from a neon that is from the same year as your car.
Old Apr 5, 2007 | 04:08 PM
BadBrads97Neon's Avatar
BadBrads97Neon
So I just yeasterday bought a pcm for a 97-99 DOHC because Im swapping to a mtx soon and needed the mtx pcm, anyway I could just use that one if I did a 2.4 swap?
Old Apr 5, 2007 | 04:11 PM
das2123's Avatar
das2123
Yep.
Old Apr 5, 2007 | 04:14 PM
BadBrads97Neon
cool cool
Old Apr 6, 2007 | 04:04 PM
streetracer603
thanks, wat problems might i have when doing the swap
