how much boost
Old Apr 10, 2007 | 02:52 PM
civiceater88's Avatar
civiceater88
Default how much boost
i just bought the modern performance bottom and top end performance rebuilt kits with #16 cams how was wondering how much boost i would be bale to run without blowing the engine????
Old Apr 10, 2007 | 03:47 PM
racerx55's Avatar
racerx55
Default RE: how much boost
whats your base compression ratio gonna be? thats the biggest part
the other important part is keeping your air fuel ratio in a safe place
Old Apr 10, 2007 | 04:03 PM
hnda8r's Avatar
hnda8r
ORIGINAL: civiceater88
Jesus, you spent a lot of money. Wish I could do that. How much did that setyou back?? That should be good enough for any amount of boost.
Old Apr 10, 2007 | 04:11 PM
spudsterier's Avatar
spudsterier
if you got the 8:1 pistons with eagle rods then they are capable of handeling 30 pounds of boost and a 300 shot of nitrous
Old Apr 10, 2007 | 04:30 PM
das2123's Avatar
das2123
WOW.....NICE!!!!!
Old Apr 10, 2007 | 04:31 PM
Dazzellerr's Avatar
Dazzellerr
you will be fine on whatever you decide to throw at it, but make the gap on the rings just a smidge sloppy, say .002 or so loose.
to compare:
buddies talon running 42 pounds of boost and a 10o direct shot on his built motor, not saying they are the same motor here, just an example. like he says, it is all in the tune. i would imagine you will be happy with 28 pounds and a 75 shot to start. in a neon with weight redux, you would be close to a 10.5 if not a litle lower.
Old Apr 10, 2007 | 04:32 PM
civiceater88
spuds are u joking becuz i spent about 2600 on that and i dont wanna do that and blow my ****ing engine ill b pissed and yes it is the 8:1
