brakes
Old Apr 11, 2007 | 02:28 AM
kingof97neon's Avatar
kingof97neon
Default brakes
ok i am wantin to know how to pit disk brakes on the back of my car and i am wantin to know how and where i can get the parts
thnx
Old Apr 11, 2007 | 04:11 PM
das2123's Avatar
das2123
Default RE: brakes
From the 1st Gen FAQ's...
Q: Can I swap my rear drums to disc brakes? Are there any advantages?
A: Yes, you will need calipers, rotors, backing plates, brake lines, and e-brake cables. Disc brakes do not add more stopping power over drums, since the rears only do about 15%-20% of the braking. The drum brake setup is actually lighter than the disc brakes, although maintenance is a bit tougher. You DO NOT have to swap your master cylinder either.
You can either surf the net for the parts or hit up a pick and pull.
Old Apr 11, 2007 | 08:01 PM
ohioguru's Avatar
ohioguru
Default RE: brakes
just a waste of money....invest in sumthin better.....my satellite has 4 drums and stops fine....and that weighs alot more than my neon
Old Apr 11, 2007 | 08:20 PM
das2123's Avatar
das2123
Default RE: brakes
Drums are hideous to look at though[:'(]
Old Apr 11, 2007 | 09:04 PM
kingof97neon
Default RE: brakes
ya the only reason i am wanting to do it is because i am going to put rims on my car and the drums look like ****
Old Apr 12, 2007 | 12:22 AM
das2123's Avatar
das2123
Default RE: brakes
ORIGINAL: kingof97neon
You can do it and it's very easy.
