ATX kickdown lever frozen
Old Apr 17, 2007 | 08:10 AM
racerx55's Avatar
racerx55
Default ATX kickdown lever frozen
anyone have an easy way to unstick the throttle downshift lever on the auto trans? its stuck moving with the shifter
pisses me off i justgave away 2 good autos now i need parts for one
Old Apr 17, 2007 | 03:32 PM
spudsterier's Avatar
spudsterier
Default RE: ATX kickdown lever frozen
i had this problem before....just took alot of PB blast and a few days....
spray...wiggle....soak...then repeat...
i thought that the kickdown unbolts from the downshift lever....but i cant exactly remember
if it does then unbolt it and clean the shaft
Old Apr 18, 2007 | 08:15 AM
racerx55's Avatar
racerx55
its stuck good, i just dont feel like taking the valve body out to get it all the way apart.suppose ill spray it again, been hosin it with PB for 2 weeks and whackin it with a hammer & cant get it to budge, im beginning to wonder if someone welded it ( its in a race car that you usually manually shift anyway)
Old Apr 28, 2007 | 10:41 AM
DOHCgarrett t3's Avatar
DOHCgarrett t3
i just had that issue too but i dont think it was that stuck cause i just kept gettin on it and it came loose itself works fine now
