Cracked Head Performance
First of all how do you know if you have a cracked head?
second is it reliable to just get it shaved?
and with a cracked head do you loose performance
And How do you even crack a head??
Generally a cracked head will leak oil into the antifreeze or antifreeze into the oil however this can also happen with a bad head gasket. The only way to verify if the head is cracked or not is to have it professionally tested.
Shaving ordeckinga head refers to machining the head to correct a warped head not a cracked head.
Yes it can affect performance as oil and or antifreeze can leak into the cylinders. Uncorrected it will destroy the engine.
but my oil level stays the same...
but ive been told that i have a cracked head by a few people becuz they new the person who had it before me
How Much DasI have SOHC ??? i might be interested as long as everything is alright with it. so should i go get a compression check???
Das Pm Me With A Price Or Just Post on Here
