Tranny swap????
No TCC error code if you do this....
But you should get an MTX PCM anyway.
ORIGINAL: fusion210
To use the automatic's computer with the swap you just have to do this.
Before you remove the auto tranny from the car and while you are draining it remove the pan.
Remove the manual valve body. http://ripcuda.50megs.com/shift.html
Take off the torque converter lockup solenoid connected to the vavle body.
Zip tie it to the wires by the side of the computer and plug it in.
Put back in the valve body and pan.
