VSS Changed
Old Apr 29, 2007 | 05:23 AM
boxerjl2's Avatar
boxerjl2
Default VSS Changed
ok Today I Change out my VSS with a new one splice all the wires together and i went to go drive and still have no Speedo WHAT IS WRONG i just paid $35.00 to waste my time and money
i got the new VSS and no speed and its not the cluster becuz its new well it might be ill check it out in my sisters Neon.
and let you know
WHATS WRONG I ASK AGAIN PLEASE HELP
in the VSS an Orange, Black withBlue, white with Orange which i believe is the speedo.
so if i fried some wires somewere can i run the wires straight from the VSS to the Cluster. ive found the white with orange going into the cluster but there are 0 orange ones going to the cluster and 0 black with blue stripe.
HMMM
Josh
Old Apr 29, 2007 | 04:14 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
Default RE: VSS Changed
duct tape!
Old Apr 29, 2007 | 07:24 PM
das2123's Avatar
das2123
Does anything on your cluster work?
Old May 1, 2007 | 12:35 AM
boxerjl2's Avatar
boxerjl2
yeah everything except the speedo and the odometer/Trip
and like i said i bought the vss bran new ill check my cluster in my sisters car to make sure thats not it.
haha she got her neon before me and was all bragging and stuff then she came over and saw my neon and got super hurt. lol
her neon has had so many problems going on in it i hope mine doesnt turn out to be like that
Old May 1, 2007 | 10:21 AM
spudsterier's Avatar
spudsterier
i have the same problem as you with my work car.....changer the vss 3 times....didnt fix it....changed 2 cluster....didnt fix it.......everything in the cluster works except the speedometer and the odometer/trip
i would like to figure this out as well....its just starting to drive me nuts not having a speedomter[:@]
Old May 1, 2007 | 04:30 PM
das2123's Avatar
das2123
Take a digital multimeter and look at the vss signal. You ought to see a 5V low frequency signal.
