DOHC Timing marks???
Old Apr 29, 2007 | 05:38 AM
impalass's Avatar
impalass
Default DOHC Timing marks???
Hello people...yes... I decided to repair my 2.0 DOHC instead of the swap for a 2.4. I already rebuild the bottom end with a rebuild kit from Modern Performance. Engine was bored 30 over, new forged pistons 12.5.1. Now I'm installing the head but I encounter a problem...I know Ihave to line up the marks in the inside of the crankshaft but my pulleys have two marks. they have the groves marks and also they have a blue dot in the outer rim, Both marks are totally different....soooo wish mark i have to line up??? I don't want to bend valves sinse I already spend too much money in this engine. Soo wich mark??????
Old Apr 29, 2007 | 12:48 PM
spudsterier's Avatar
spudsterier
Default RE: DOHC Timing marks???
use the perminent marks....which would be the notches
Old Apr 29, 2007 | 12:50 PM
racerx55's Avatar
racerx55
you line up the stamped grooves. the paint marks should both go toward each other, butdont line those up, make sure its the groove in the pulley that you line it up by
