Rear sway bar ?
Old Apr 29, 2007 | 07:11 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
Default Rear sway bar ?
so if my car is not already equiped with a rear sway bar and i want to add one what do i need to do? and what parts do i need.
i have the eibach sway bar kit for the front and rear. but im not sure if all the parts are there either. so in addition does anyone have the parts list for this kit?
Old Apr 29, 2007 | 07:18 PM
das2123's Avatar
das2123
Default RE: Rear sway bar ?
You will need:
Frame brackets and bushings;
The bar[/b];
End links and bolts;
End link - strut mount brackets.
Old Apr 29, 2007 | 09:17 PM
DOHCgarrett t3
and i forgot to add that i have drum brakes. i never got a chance to swap them out when i was home. does that make a diffrence?
Old Apr 29, 2007 | 10:54 PM
spudsterier's Avatar
spudsterier
no they will still be the same
Old Apr 29, 2007 | 11:19 PM
DOHCgarrett t3
okay good cause i seen on one website somewhere that they were diffrent so i guess thats better that they are the same
Old Apr 30, 2007 | 02:41 AM
das2123's Avatar
das2123
ORIGINAL: DOHCgarrett t3
Sway bar has nothing to do with the brakes. The brackets bolt up to the struts.
