Speaker problem
Old May 2, 2007 | 12:32 AM
yungmain23's Avatar
yungmain23
Default Speaker problem
Ok, my left speaker in the door works fine but i put the same one into the left side but it didnt work so i tried new speaker wire but it still didnt work. I checked all the connections an they are just fine. what could it be?
Old May 2, 2007 | 06:05 AM
unclemike's Avatar
unclemike
Default RE: Speaker problem
Radio going south?
Old May 2, 2007 | 08:32 AM
DOHCgarrett t3's Avatar
DOHCgarrett t3
im a bit confused you said you took the left speaker and put it in the left side? if you tried new wire and still nothing then the head unit is bad
Old May 2, 2007 | 10:29 PM
yungmain23's Avatar
yungmain23
the head unit is pretty new, ive only had it like 6 months. Its an Alpine and it had been workin fine. i tried the speaker from the left side on the right side is what i meant.
Old May 3, 2007 | 12:09 AM
DOHCgarrett t3
try a new head unit or if you still have stock radio. try that one. hopefully you used a wiring harness adapter and didnt splice into the stock wires
