code 25
Old May 5, 2007 | 03:27 AM
95neonriceeater's Avatar
95neonriceeater
Default code 25
i know it's a vacuum leak or something to do with that
where could it be?
could it be anything else?
btw
when i went to pick-n-pull today i couldn't find a 2nd gen center console
but i found a 96 ACR
it was WRECKED
the whole passenger side was caved in
i was going to try to get the sway bar, but it was bent
i was going to get the suspension
but there was only 3 there
i was going to take the rims
but there were only 2
then i was going to get the PCM
but it wasn't even there
so today hasn't really been the best day...
Old May 5, 2007 | 04:52 AM
das2123's Avatar
das2123
Default RE: code 25
Check vacuum lines and maybe clean your TB.
Old May 5, 2007 | 05:05 AM
95neonriceeater
Default RE: code 25
the vacuum line is connected and everything
i'm thinking it's most likely the TB now that you bring it up
how would i go about cleaning it?
Old May 5, 2007 | 05:08 AM
das2123's Avatar
das2123
Default RE: code 25
Mopar Combustion cleaner will work. Clean the IAC while you are at it...may need to be replaced.
Old May 5, 2007 | 05:11 AM
95neonriceeater
Default RE: code 25
sorry because i really dont remember
but whats the IAC again?
Old May 5, 2007 | 12:28 PM
das2123's Avatar
das2123
Default RE: code 25
Idle Air Control motor. It's connected to the TB.
Old May 5, 2007 | 06:01 PM
95neonriceeater
Default RE: code 25
yea i figured that out once i signed of df and felt like a dumby[>:]
