1996 neon
Old May 7, 2007 | 07:59 PM
attd27's Avatar
attd27
Default 1996 neon
2 problems Im having the throw out bearing is making noise after new clutch and bearing were replace????????also the car runs like crap until it warms up any one can help with these problems.......would be greatly appreciated.....thanks
John
Old May 7, 2007 | 08:09 PM
spudsterier's Avatar
spudsterier
Default RE: 1996 neon
sounds liek the running problem might be an 02 sensor
you might wanna check your tranny fluid and make sure there is enough in there since that could be what is causing your noise
