SRT-4 seats in a coupe?
Old May 9, 2007 | 02:20 AM
neoncrazy101's Avatar
neoncrazy101
Default SRT-4 seats in a coupe?
i know all Neon seats are interchangable. but does that include the coupes?
Old May 9, 2007 | 03:49 AM
NEONRT98's Avatar
NEONRT98
Default RE: SRT-4 seats in a coupe?
I think you answered your own question...
But to add to that.. if oyu put the SRT-4 seats in a coupe, it might be hard to get into the back seat because they dont lean forward
Old May 9, 2007 | 03:52 AM
neoncrazy101
ORIGINAL: NEONRT98
thats where the question came into. if they fold lean forward then i cant use the back seat. but they do recline, so couldn't they be like "flipped" so to speak to lean forward? or is it all on the seat bracket? as you can tell coupes are not my cup of tea,.
Old May 9, 2007 | 10:11 AM
spudsterier's Avatar
spudsterier
the part that makes the seat flip forward on a coupe is actuallin the seat back.....the bracket on the sides of the seats that holds the bottom to the back is different on the coupes then it is on the sedans
Old May 9, 2007 | 12:09 PM
das2123's Avatar
das2123
You can swap the brackets and make the SRT-4 seats fold forward....
ORIGINAL: Corprin
Items Needed;
10mm socket with wrench (3/8" drive or larger)
flat blade screwdriver
torx (can't remember what size)
outside seat back brackets from 1g coupe
Bracket Removal,
1. Remove plastic cover from seat back adjustment lever, with torx driver.
2. Use flat blade screwdriver to carefully unclip seat back cover clip and peel seat cover up and out of the way.
3. Using the 10mm ratchet, remove all four bolts attaching the stock bracket to seat bottom and back.
4. Bolt on 1g coupe bracket using the stock bolts
5. Replace seat back cover, slipping plastic release under seat cover (I didn't cut it, but you can) and clip on bottom of cover.
6. Replace plastic adjustment lever cover.
