Timing belt
Old May 10, 2007 | 05:06 PM
treeboa's Avatar
treeboa
Default Timing belt
I might be buying a 95 Neon SOHC from my sister in law. When do you guys recomend changing the timing belt? My 97 Neon Sport DOHC broke the timing belt and messed up the valves and head at 113,000 miles. The 95 has 108,000 miles on it. Thanks in advance.
jeff
Old May 10, 2007 | 05:13 PM
95neonriceeater's Avatar
95neonriceeater
Default RE: Timing belt
once you get it just change all the gaskets and belts if they haven't been changed yet
Old May 10, 2007 | 07:47 PM
spudsterier's Avatar
spudsterier
the timing belt should be changed every 100,000 miles
Old May 10, 2007 | 08:47 PM
treeboa's Avatar
treeboa
Thank guys. I will take your advice.
