injectors
Old May 11, 2007 | 07:15 PM
ghost_neon's Avatar
ghost_neon
Default injectors
does anyone know where i might be able to find larger injectors for my 95 neon? or if the automatics' injectors are larger or not?
also, if anyone knows where i could get a SOHC turbo header?
thanks
Old May 12, 2007 | 12:41 AM
das2123's Avatar
das2123
Default RE: injectors
Only reason you would need bigger injectors is if you do a 2.4 swap or are boosted. But here are some from Modern Performance...
http://www.modernperformance.com/all...njectors.shtml
Old May 20, 2007 | 03:22 PM
ghost_neon's Avatar
ghost_neon
well i am turbocharging my neon but i still need a header and some good piping for the turbobut as for the injectors, the PPH. what exactly would i need , for instance, how large of injectors would i need. im aiming for about 12-15 lbs of boost. im not all the familiar with turbocharging a 4 cylinder, i dont know the boost range i should be going for, so any help someone could give me i would be much appreciated
Old May 21, 2007 | 01:49 AM
das2123's Avatar
das2123
ORIGINAL: ghost_neon
If you are turbocharging your car, WHY would you need a header
Old May 21, 2007 | 10:02 AM
spudsterier's Avatar
spudsterier
maybe he means a manifold.....i have noticed that alot of people say one when they mean the other
Old May 21, 2007 | 03:19 PM
ghost_neon's Avatar
ghost_neon
the exhaust manifold, my mistake lol.
