96 neon rear disk info
Old May 12, 2007 | 06:20 PM
tandc972003's Avatar
tandc972003
Default 96 neon rear disk info
I know I need disk ,Caliper ,lines ,e-brake cables and pads is their anything else I need to change drums to disk And if anyony has the cable, performance disk or calipers for sale sale I need them
Old May 12, 2007 | 08:19 PM
estneon's Avatar
estneon
Default RE: 96 neon rear disk info
why would you change to disk brakesthereheavier than drums and they dont reallyprovide any extra braking power in the rearits awaist of money and time
Old May 12, 2007 | 09:51 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
it looks better when you have rims and its not that much money. go to the junk yard and pull off everything from the 2 bolts on the strut and on plus brake cable and e brake cable
Old May 13, 2007 | 02:33 AM
das2123's Avatar
das2123
ORIGINAL: tandc972003
Looks like you got it all. You will also need a 30mm nut to get your drum hub off.
ORIGINAL: estneon
It's so much better to luck and change pads though. They aren't that much heavier...maybe 5 lbs per side.
Old May 13, 2007 | 02:05 PM
DOHCgarrett t3
amen to changing the pads. not that the rear you have to change as often but it its a lot eaiser.
Old May 13, 2007 | 04:16 PM
95neonriceeater's Avatar
95neonriceeater
are there any differences from the sport rear brakes and the r/t-acr rear brakes?
Old May 14, 2007 | 11:19 AM
das2123's Avatar
das2123
ORIGINAL: 95neonriceeater
Nope.
Old May 14, 2007 | 01:52 PM
95neonriceeater
alright thanks das
there are a lot of sports at pick-n-pull
Old May 14, 2007 | 04:18 PM
95neonriceeater
is it hard to take off the brake lines and everything from the doner car?
and is it hard to swap all the brake lines in?
pictures of everything would be nice and appreciated if anyone has any
Old May 14, 2007 | 04:50 PM
das2123's Avatar
das2123
No and no. It's more simple than you think. Below is what you need minus the knuckles.
