speedometer problems PLEASE HELP!!!
Old May 15, 2007 | 10:26 PM
hsico's Avatar
hsico
Default speedometer problems PLEASE HELP!!!
We replaced the electronic board on the dash with a brand new one from Chrysler. Now all gages work but speedometer doesn't. 1995 Dodge Neon
Old May 16, 2007 | 02:37 PM
das2123's Avatar
das2123
Default RE: speedometer problems PLEASE HELP!!!
Did your odometer stop working as well? If so, you have a bad VSS (vehicle speed sensor).
I am almost afraid to ask how much the new cluster cost from the dealer. You can probably take it back since it did not fix your problem.
Old May 18, 2007 | 06:46 PM
hsico's Avatar
hsico
We replaced that also and it still doesnt work. We dont know what else to do.
Old May 18, 2007 | 07:41 PM
neon15's Avatar
neon15
I had the same problem....i took of the cluster and resoldered all the connections and it worked well
Old May 19, 2007 | 01:35 AM
neoncrazy101's Avatar
neoncrazy101
before i learned about the re-soldering the connections, i got a qoute from a dealership and it was $400. but then i went on ebay and bought one for $40.
Old May 19, 2007 | 01:48 PM
das2123's Avatar
das2123
ORIGINAL: hsico
You may have to look at the connections where the cluster plugs into. Your problem may be there.
