PCM?
Old May 17, 2007 | 03:21 PM
neon527's Avatar
neon527
Default PCM?
wanted to know if a DOHC mtx pcm will work on a SOHC atx but will be doin the mtx swap? does it matter? or if i will get any error codes?
Old May 17, 2007 | 03:28 PM
95neonriceeater's Avatar
95neonriceeater
Default RE: PCM?
it does work but i think that your SOHC will run richer than it is supposed to
Old May 17, 2007 | 05:26 PM
das2123's Avatar
das2123
Default RE: PCM?
As long as you get the correct year DOHC PCM. 95 uses a 95, 96 uses a 96, 97-99 can interchange.
Your car will run a little rich as mentioned
Old May 17, 2007 | 05:35 PM
loud99R/T's Avatar
loud99R/T
Default RE: PCM?
if he swaps the PCM before he does the MTX xwap doesnt he need a lockuptorque converter switch to do it manualy?
Old May 17, 2007 | 05:59 PM
das2123's Avatar
das2123
Default RE: PCM?
ORIGINAL: loud99R/T
Yes. I was assuming he would swap the PCM after the tranny swap.
Old May 17, 2007 | 09:39 PM
neon527's Avatar
neon527
Default RE: PCM?
yeah when i was going to do the swap i am going to install the pcm with the tranny!!
