"oil leak"
Old May 18, 2007 | 02:41 PM
villarreal's Avatar
villarreal
Default "oil leak"
hey i just bought a 1999 dodge neon and i have a pretty good sized oil leak and cant figure out where its comming from, i have to put oil in like ever other day, any one have any idea that might help me,please
Old May 18, 2007 | 03:02 PM
neisg1's Avatar
neisg1
Default RE: "oil leak"
What general area is the leak?
Old May 18, 2007 | 03:52 PM
das2123's Avatar
das2123
All these places are common leaks:
*camshaft position sensor
*headgasket
*oil sending unit
*valve cover gasket
*rear main seal
Old May 18, 2007 | 09:32 PM
villarreal's Avatar
villarreal
not sure really pretty sure its coming from the back of the motor from three places
Old May 19, 2007 | 05:47 AM
racerx55's Avatar
racerx55
you gotta clean it all off then run it and try to find the source. if the valve cover or cam sensor leak it runs down the head and transmission all over hell and it can be hard to track down or could be mistaken for a rear main seal.
is it coming off the transmission front or rear? just the back ofthe oil pan somehwat beside the drain plug or what?
