Running Very Rich
Old May 19, 2007 | 04:55 PM
Carbine34's Avatar
Carbine34
Default Running Very Rich
Hi all i have a few questions i hope can get answered.I have a 96 neon 2.0 sohc thats running rich.I have changed the fuel filter,pcv valve,plugs,and went through about 2 o2 sensors the maniflod ones.It will run fine for about a day then the gas milage gets eatin fast and the service light will come back on.when i change the plugs i can tell theres a ton of fuel being pumped there covered.I have gone through 2 02 sensors allready as i have stated.And the oil is very fuel contaminated.any suggestions or advice would be great thanks
Old May 19, 2007 | 06:19 PM
neon15's Avatar
neon15
Default RE: Running Very Rich
Check Engine light?
i had the same problem and did everything you did and it turned out being the coolant temperature sensor ( i have a '96 SOHC also).
Good luck
Old May 20, 2007 | 01:18 AM
Carbine34's Avatar
Carbine34
Yes check eng. light comes on if i change the plugs and o2 sensor on bank 1 the light goes out for about 1 day.Then comes back on il have to check the temp sensor and see if that helps thnx for the suggestion neon15
Old May 20, 2007 | 03:09 AM
das2123's Avatar
das2123
I'd also inspect the wiring to the O2 sensors.
Old May 20, 2007 | 11:25 AM
neon15's Avatar
neon15
Go to autozone or somewhere and have them run the codes
