wanting to build sohc cam
Old May 20, 2007 | 01:28 AM
tandc972003's Avatar
tandc972003
Default wanting to build sohc cam
I would like to build a sohc from bare block I was wanting to get a good parts list to make the most power and strongest motor
Old May 20, 2007 | 02:52 AM
95neonriceeater's Avatar
95neonriceeater
Default RE: wanting to build sohc cam
bore it out the block to .20 over
get eagle rods and JE pistons
crane #14 cam if you arent going turbo
crane #12 if you are going turbo
dont forget to get the crane vavle springs
indy or a custom intake manifold
possibly long tube header if you dont have immisions
if you do get a pacesetter header
for the throttle body get either a 55mm or 57mm
also port and polish the head
either get it professionally done or do it yourself with a dremel
if i'm missing anything or mistook something then someone correct me!
good luck man
Old May 21, 2007 | 01:56 AM
das2123's Avatar
das2123
Follow this setup...
http://www.roachracing.net/
