non tach to tach cluster.
Old May 23, 2007 | 01:05 AM
neoncrazy101's Avatar
neoncrazy101
Default non tach to tach cluster.
I know Neons have it pre-wired and such. but is that just for the 95-96? my 97 doesn't have a tach and i want to swap one in but does the '97's have it pre-wired as well?
Old May 23, 2007 | 01:07 AM
jakedlee16's Avatar
jakedlee16
Default RE: non tach to tach cluster.
iunno i have a 95 auto with no tach and im want to install a dash with a tachtoo ...
Old May 23, 2007 | 01:21 AM
neoncrazy101
its pre-wired with yours jake. so you can just buy a cluster with the tach and it will work.
Old May 23, 2007 | 01:58 AM
neisg1's Avatar
neisg1
From what I’ve read all the 1st gen Neon’s were per wired for a tach. with the possible exception of some of the early 95’s that may required an additional wiring kit.
Also see this thread.
https://dodgeforum.com/m_482936/tm.htm
It should also be noted that there are at least two different tach. clusters 7krpm and 8krpm.
The ones I have on the 8k it has a door ajar light while the 7k has a hazard indicator light socket that is not used.
Old May 23, 2007 | 01:37 PM
das2123's Avatar
das2123
ORIGINAL: neoncrazy101
Yes it is.
Old May 23, 2007 | 09:06 PM
ohioguru's Avatar
ohioguru
i had to buy a tach driver to power the one on my 96....it was in no way prewired......
Old May 24, 2007 | 11:45 AM
das2123's Avatar
das2123
ORIGINAL: ohioguru
Thats odd because my 96 is
