motor boging down
Old May 23, 2007 | 08:04 PM
tandc972003's Avatar
tandc972003
Default motor boging down
my car seems to bog down when i push down on the throttle I think its getting to much gas also my ce ligkt is on it gives me 21 twice
Old May 24, 2007 | 12:06 AM
neisg1's Avatar
neisg1
Default RE: motor boging down
Code 21 is an O2 sensor probably the one in the manifold there is a 2nd one after the catalytic converter.
If you use a code reader it will tell you which one is bad
Old May 24, 2007 | 01:11 AM
spudsterier's Avatar
spudsterier
in order to cause the car to bogg down it will most likely be the 02 sensor in the manifold that owuld be bad
Old May 24, 2007 | 01:49 AM
das2123's Avatar
das2123
ORIGINAL: spudsterier
XO, "I concur"
Old May 24, 2007 | 08:39 PM
tandc972003
I replaced that one twice I thought that I got a bad one the first time but I was getting I diffrent code then. this code came on about a week after I put on a new cat I thought I might have pulled I wire loose or something but I dont know what tools I need to test the wires going to the o2 or witch is pos and neg when I had auto zone run a code check on it today and they said it is basicly saying the o2s are not there what wire goes to both of them
Old May 24, 2007 | 11:28 PM
das2123's Avatar
das2123
Check your wiring to the sensors.
