transmission gaskets
is there a special gasket i need for the tranny to bolt up to the block and for the tranny case to bellhousing. also on the endplate to case. help soon please
end plate uses permatex or any kind of gasket maker.....otherwise thats it..no other gaskets
case>bell housing and trans>block all seal pretty tight when the bolts are tightened down, and dont leak anything
