f**king alternator!!!!!!
Old May 26, 2007 | 04:31 PM
pssssst's Avatar
pssssst
Default f**king alternator!!!!!!
ok... me and my friend have been working at the alternator for a total of 4 hours....we need to just get the 2 loosening bolts loosened so i can remove the belt to get to the timing belt..... it literally took 3 hours of us sprayin it with penetrating oil and just wrenching on it to get the bottom loosening bolt broke loose.... but now that it finally broke loose it is spinning in place! what can i do!!!???
Old May 26, 2007 | 05:54 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
Default RE: f**king alternator!!!!!!
that bolt is about 5 inchs long and on the other end of it was or is an L bracked attached to a nut
maybe get a set of vice grips in there to get a good grip in it and then try loosening it I dont know if you can remove the whole thing bracket and all and be able to get it out of there but you could try
