HELP! did a tranny swap car wont start????
Old May 29, 2007 | 02:04 PM
neon527's Avatar
neon527
Default HELP! did a tranny swap car wont start????
had a SOHC ATX changed to aMTX did everything in the tranny swap forum that was posted, car cranks but wont turn al the way on any ideas ???? need help asap please!!!!
Old May 29, 2007 | 02:08 PM
neon527's Avatar
neon527
Default RE: HELP! did a tranny swap car wont start????
oh yeah one problem still using the atx pcm, couldnt find a mtx pcm with a 4 row prong setup at a local junkyard, the only ones i found were 3 row?? could using the atx pcm bepart of the problem??
Old May 29, 2007 | 02:09 PM
das2123's Avatar
das2123
Did you ground the park/neutral safety switch?
Old May 29, 2007 | 02:11 PM
neon527's Avatar
neon527
yes i did
Old May 29, 2007 | 02:15 PM
das2123's Avatar
das2123
Have you checked for fuel or spark?
Old May 29, 2007 | 02:18 PM
neon527's Avatar
neon527
jus got done doin that, got gas even put a bottle of octane booster, n spark is ok!! the clutch start switch has nothing to do with it would it??
Old May 29, 2007 | 02:34 PM
das2123's Avatar
das2123
Did you check the fuel pressure at the rail? Not just that you had fuel in the car. I'd double check all your wiring. What happens when you try to start the car? Is it cranking and not just turning over?
Old May 29, 2007 | 02:46 PM
neon527's Avatar
neon527
yes everything is fine now the problem when i took at the pcm to clean it n when i put it back in it wasnt connected all the way in, but thanks for the help it rides like a beauty!!!!!!!!!
Old May 29, 2007 | 09:20 PM
godxld50's Avatar
godxld50
yeah you should switch ur pcm to the mtx pcm. that could be part of the reason why your car wont start!
Old May 29, 2007 | 11:27 PM
das2123's Avatar
das2123
ORIGINAL: godxld50
An MTX will run with an ATX PCM.
