Alright guys... Its not been my day, let me tell you.... I cant get these brakes bled.. I am using the 1st gen master cylinder.. I can get the front drivers bled, but not any of the others.. All the brake lines are fine. I disconnected all of the lines from the master cylinder (4 lines, disk brake w/o ABS) and pushed the pedal, I am only getting fluid out of the back right location (goes to the caliper I am able to bleed). When I push the pedal in the car, it sounds like the master cylinder is bottoming out or something... I need help, because I dont want to sink 200 bucks into a new master cylinder if I dont need one! Any suggestions? This thing worked before I started the project, and I never opened it up!
