rear motor mount (spud Das racerx?)
Old May 31, 2007 | 02:41 AM
neonracer1010's Avatar
neonracer1010
Default rear motor mount (spud Das racerx?)
how in the hell do you get it in the whole thing not just the insert but the metal part and all. ive been in the proscees of changing trannys as many of you know and im almost done about 5 months later, and i cant figure out how to get that rear mount in there, or how it lines up with the holes on the top of the tranny. any help at all would be great
Old May 31, 2007 | 11:15 AM
spudsterier's Avatar
spudsterier
Default RE: rear motor mount (spud Das racerx?)
mount the bobble strut in the hole on the tranny mount first.....then give the bottom of the strut a hard pull and see if you can pull it out a little more.....if not, then remove the big bolt in the front motor mount...that will allow you to swivel the motor back and forth......place a jack under the front mount and jack it up....that should give you enough slack to get the cross bolt in the bottom of the bobble strut...
dont know if you follow me on this.....but i tried[&:]
Old May 31, 2007 | 12:57 PM
neonracer1010
nope dont follow you at all. i never took the boble strut out. and it took forever last nite to get the front mount in.
Old May 31, 2007 | 04:15 PM
spudsterier
well then which rear mount are you talking about
Old May 31, 2007 | 06:31 PM
neonracer1010
the one that goes onto the tranny
Old May 31, 2007 | 06:42 PM
BadBrads97Neon's Avatar
BadBrads97Neon
Are you talking about the long tranny to engine brace or the actual mount that is near the PCM? Im confused..sorry..
Old May 31, 2007 | 06:48 PM
boxerjl2's Avatar
boxerjl2
were do you even get a new rear motor mount i checked modern peformance and all they have it the front one
i believe hes talking about the one that looks like a shock spring
well thats the one im talking about it in the rear of the engine the only thing that looks like a motor mount
Old May 31, 2007 | 07:28 PM
spudsterier
if its the mount on the drivers side under the pcm then put a jack under the tranny and lower it as far as it can go....from there, if you have the tire off then you can maneuver the mount in from the wheel well.....use a long extension to get the top bolt in and the 2 side bolts can be reached from the wheel well.....then just jack the tranny up and the mount will slide into place on the car......then put the long bolt in through the wheel well
