Problems to expect?
Old May 31, 2007 | 12:38 PM
beemik's Avatar
beemik
Default Problems to expect?
My girlfriend is currently looking to buy a 1998 neon sport. What kind of problems if any can i expect from this year neon? The car has 112,000km or about 68,000miles on it, and it's an auto. The cost is $3999CAN from a dealer.
Old May 31, 2007 | 02:24 PM
das2123's Avatar
das2123
Default RE: Problems to expect?
Check to see if it has the newer, better multi-layered steel headgasket (MLS HG)...
http://www.myneonspeed.com/howto/howto_1stgen_mls.htm
The timing belt, water pump and idler pulley should all be changed every 100,000 miles so keep that cost in mind when purchasing the vehicle.
Old May 31, 2007 | 06:50 PM
beemik's Avatar
beemik
Great! Thanks. Are there any common problems?I have a 95 corolla and (it was givin to me) I am now stuck doing the valve seals because they start failing at around 100,000 miles. Can I expect anything like that?
Old May 31, 2007 | 06:55 PM
das2123's Avatar
das2123
Kinda hard to say because it depends alot on the previous driver.
Old May 31, 2007 | 11:22 PM
rrwertz's Avatar
rrwertz
Seems kind of expensive, but you are buying it from a dealer. I'd never make that mistake again.
Old Jun 1, 2007 | 11:01 AM
beemik's Avatar
beemik
Thanks! i thought it might be a little bit too much too but like you said it's from a dealer. Havn't bought it yet so i will do some looking around. my girlfriend is heart set on a neon 98/99.
Old Jun 1, 2007 | 04:38 PM
95neonriceeater's Avatar
95neonriceeater
i wish my girlfriend liked neons that much
