wastegate
Old May 31, 2007 | 08:26 PM
mmench's Avatar
mmench
Default wastegate
since i havent really tuned alota turbo cars and havent messed with waste gates before i have a few questions. i am plannin on using either an agp or forge wastegate. wen i go to tune my boost levels i only want to run 5 pounds on the street. my question is....
1) how do i setup the wastegate to run low boost like that?
2) do i use different springs or adjust the actuator lever.?
3) will using different bov springs change anything with regard to the bov?( i have a forge bov with like 4 different springs to choose)
Old May 31, 2007 | 11:23 PM
spudsterier's Avatar
spudsterier
Default RE: wastegate
the arm on the wastegate adjusts by just turning it and then tighten the jam nut........the longer the lever, the less boost you will see....unscrew it as far as you can....then tighten it about 1/4 inch...that should be about 2-3psi from there you will have to adjust it as you have the car running
couldnt tell you about the blow off valve....i have the mopar plate style on mine
Old Jun 1, 2007 | 01:12 AM
mmench's Avatar
mmench
yea last weekend i went and met a guy to buy his intercooler. he had another turbo for me and forge bov, srt injectors and gaskett or intake manifold. the bov has like 4 extra springs with it so i figured id ask
Old Jun 1, 2007 | 01:13 AM
mmench's Avatar
mmench
how is the forge wstegate and agp wastegate compared to each other side by side
Old Jun 1, 2007 | 01:26 AM
spudsterier
both are basically the same....just a different name
Old Jun 1, 2007 | 06:33 AM
racerx55's Avatar
racerx55
different springs for thebov are for higher boost levels, you want to keep a weaker sping in so it opens faster and easier and keeps surging to zero or to a minimum, but the spring will only hold so much boost before it leaks under boost. a stiffer spring will make it louder because its harder to open and wont open as far but also that makes the turbo slow down faster between shiftsfrom the extra backed up pressure.
