Rad Hose..
Old Jun 4, 2007 | 02:28 AM
joecool6101's Avatar
joecool6101
Default Rad Hose..
I have been trying the past 2 days with no luck getting my rad hose off at the bottom of the rad..
The clip was super rusted and broke in half.. so there is half a clip holding it on... it is pissing out coolant when ever i move the hose.
It has just become impossible for me to get to it and take it off.. please note that i dont really have a jack.. i do but its one of those cheap ones for changing your tire when your in a bind.. Suggestions would be appreciated
Old Jun 4, 2007 | 02:33 AM
spudsterier's Avatar
spudsterier
Default RE: Rad Hose..
take out the radiator fans....it gives you alot more room to work from the top..
you could also consider using a razor blade and cutting the old hose off....then just replace with a new one
Old Jun 4, 2007 | 02:55 AM
joecool6101
ORIGINAL: spudsterier
I orginally was going to save the hose and just out new clamp on it.. now i think to totally stop the leak i am having replacing the entire hose would be the best option..
Old Jun 4, 2007 | 11:54 AM
das2123's Avatar
das2123
Replace the hose.
Old Jun 5, 2007 | 12:30 AM
NEONRT98's Avatar
NEONRT98
ORIGINAL: joecool6101
And uh... drain the radiator first... [8D]
