Cut The Rice Let It Rumble
Old Jun 14, 2007 | 01:26 AM
  #21
95to96transplantneon's Avatar
Default RE: Cut The Rice Let It Rumble
Heres what I did, go to the junk yard and find a camaro, that has the single in duel out. cut top of mufler off like about a 12 by 8 rectangle and get in there and take out all the baflling. weld top back on and it will mount right up. However if you remove your converter it wil deepen the tone.Dont know if you will be able to see it to well but theres mine.
[IMG]local://upfiles/61619/94EA3AF02CE1447B9C4F90DB80606F74.jpg[/IMG]
Old Jun 14, 2007 | 05:28 AM
  #22
boxerjl2's Avatar
boxerjl2
baffling?? just cut the rectandle any were
ohohoh ok your talking about the square box thing not the pipe wew i was confused man im tired
how much for the muffler at junk yard??
Old Jun 14, 2007 | 05:43 AM
  #23
95neonriceeater's Avatar
95neonriceeater
you can get a muffler from a junkyard for around 15 if its a stock muffler
i found a glasspack with a tip and got it for more
if you're interested i'll take a picture of it for you
Old Jun 14, 2007 | 05:01 PM
  #24
boxerjl2's Avatar
boxerjl2
what is the baffling i tried to find it on google but could not get an answer so i figured i would ask
Old Jun 14, 2007 | 10:03 PM
  #25
boxerjl2's Avatar
boxerjl2
ok baffling is the stuff that muffles it
so will it be just a box with two holes comming out for the pipe how
am i gonna run the pipes
if someone could get under there car and take at picture of the pipes running
