FS: 56mm tb, vc's, gauges/pod, more
Old Jun 12, 2007 | 11:45 AM
rrwertz's Avatar
rrwertz
Default FS: 56mm tb, vc's, gauges/pod, more
rrwertz@gmail.com
aim-rrwertz
Charleston (Cottageville), SC 29435
Pictures available upon request.
paypal or money orders only, cash if local.
56-57mm tb. stock tb bored by mpx.works great, good idle. $75
52mm tb. with 97-99 sensors. $40
-3 8K and 1 7K tach cluster. each was tested.
2 are soldier specials- $5 each
1 8k is good, but 2 bottom tabs are broken. works well though $25
1 8k speedo is kind of wierd, works, but bounces a little. $10
don't know how i got such a range...
PT waterneck. $20
-Faze single gauge pod. 1 screw hole that held it to pillar. $10
-2 5/8' autometer water temp gauge. new, only opened to verify contents.. $25
- apc oil pressure gauge. new. no sending unit. $5
-2.4 valve cover from a stratus. super clean. $30
-2.4 valve cover from an avenger. $30
-coil pack from a 2.4 stratus. with pigtail. $10
-2.0 and 2.4 (pt) heater lines. good shape. $5 each
-shifter assembly from an rt. no rips or tears. no bushings. $15
More to be added once I look around.
Old Jun 12, 2007 | 12:50 PM
mmench's Avatar
mmench
Default RE: FS: 56mm tb, vc's, gauges/pod, more
i wouldnt mind havin that 57mm tb
Old Jun 12, 2007 | 02:45 PM
rrwertz's Avatar
rrwertz
paypal it up and it's yours. i think it actually performed better than my 60mm. this was in conjunction with a 3.0 intake rather than the iceman as well. sometimes cheaper is better!
Old Jun 14, 2007 | 06:45 AM
rrwertz's Avatar
rrwertz
bump
