Please HELP!!!
Old Jun 13, 2007 | 08:56 PM
IzDatAneon's Avatar
IzDatAneon
Default Please HELP!!!
Can anyone help me out..I'm really going through it with this swap. I'm trying to swap my 95 SOHC out for a DOHC..not realizing until it was to late that the 95 in non interchangeable..I'm having trouble finding 95 DOHC parts let alone a whole motor...But I did come across a 95 DOHC in a Sebring..but the motor is reverse..the exhaust is on the front and intake is on the back...!!! Does anyone know if I can use the harness and the sensors off of it at least?? Or does anyone know where I can get my hands on a 95 DOHC?? Thanks...
Old Jun 14, 2007 | 05:34 AM
95neonriceeater's Avatar
95neonriceeater
Default RE: Please HELP!!!
95 motors are non interchangable?
someone on here has a 95 ACR with a 96 SOHC motor...
and i dont think that the sebring motor will work since it's reverse
i could be wrong though!
Old Jun 14, 2007 | 11:40 AM
das2123's Avatar
das2123
You can use any motor from 95-99 for your car. You would keep your wiring harness, sensors and intake manifold and use those on the newer engine. You may have to splice a few sensor wires together.
Or you could get the whole new engine wiring harness and PCM.
The 95 sebring has the 420a engine which you cannot use in the neon (easily).
