atx throttle body?
Old Jun 17, 2007 | 02:38 PM
mulletman11's Avatar
mulletman11
Default atx throttle body?
what tools do i need to grab one off an existing neon from a scapyard
is there a certian way to mount it on my car
please help
Old Jun 17, 2007 | 02:53 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
Default RE: atx throttle body?
no certain way just make sure you use the butterfly spring from the MTX TB
Old Jun 17, 2007 | 03:38 PM
racerx55's Avatar
racerx55
why dont you go look at your car and see what tools it takes to take your TB off.......
Old Jun 17, 2007 | 04:37 PM
mulletman11
???-why dont you go look at your car and see what tools it takes to take your tb off........
because i am young and just starting to learn about my car. i just wanted some advise, not a smart remark.
thanx
Old Jun 17, 2007 | 07:26 PM
racerx55's Avatar
racerx55
its easier to go do it on your car than to have us try to tellpeople somtimes.
most junk yards will pull it for you too.
take side cuts, hack the cables, hack the wires and the 2 bolts to the intake (13mm socket and long extension if i remember right)& it'll come off.
Old Jun 17, 2007 | 08:20 PM
mulletman11
i only hesitate because this is my only car and i dont want to mess up
so i cut the cables, unbolt and that is it?
seems easy
thanx man
Old Jun 17, 2007 | 08:31 PM
DOHCgarrett t3
Cut the one at the junk yard not on your own car lol
Old Jun 17, 2007 | 08:41 PM
mulletman11
good idea. ima go do that tomorow after work. thanx i didnt even think of that
Old Jun 17, 2007 | 08:50 PM
spudsterier's Avatar
spudsterier
you could just bring a pair of pliers and pull the cables out of the bracket that holds them on
just squeeze the plastic square part in the by the bracket, un clip it from the tb and pull them out...
remove the 2-13mm bolts and unplug the 2 wire plugs and your good to go.....
just remember....if you have cruise controll, you will need to find a throttle body from the same year or close to it for your cruise to work....
here is what i mean:
the clip that holds the cable on the butterfly from your cruise actuator uses a different style clip from 95-96 and 96-99......so if you have cruise, make sure to check what all the clips look like on the tb before you go to the junk yard.....but if you dont have cruise then you dont have to worry about it
i like having the atx butterfly spring on my r/t.....takes a bit to get used to, but its really easy on the foot
Old Jun 17, 2007 | 09:09 PM
DOHCgarrett t3
i got a dumb question
why do hot dogs come in packages of 10 and hot dogs come in packages of 8?
no kidding real question why the F-k would dodge waste the time designing and manufacturing 2 diffrent style TB
