dashboard ground
Old Jun 18, 2007 | 08:01 PM
pssssst's Avatar
pssssst
Default dashboard ground
i was jw.. the metal sections of the dashboard that basically hold the entire section in place.... can those be used as a ground source??? thanks
Old Jun 18, 2007 | 10:33 PM
pimpberetta's Avatar
pimpberetta
Default RE: dashboard ground
I believe you can. Underneath the dash I've used the metal "cage" for grounding out little do dads when I had them lol
Old Jun 19, 2007 | 12:22 AM
DOHCgarrett t3's Avatar
DOHCgarrett t3
you talking about the 2 inch piece of tubular steel? yes thats a great ground, i pre drill a hole and use a 1/4 inch zip screw for sheet metal they work great
Old Jun 19, 2007 | 10:26 AM
spudsterier's Avatar
spudsterier
you can basically use any metal in the car for a ground......
